TwinTurbo.NET: Nissan 300ZX forum - No there is a part and procedure to replace.
Draker (Eugene, OR)
on November 05, 2011 at 12:18 PM
Timing is stable at 23 when at idle. When I give it more
posted by z32z
on November 05, 2011 at 09:38 AM
Sounds like your timing is off though. Check the CAS pin first of course. Also, make sure you are checking the timing correctly as mentioned above.
Does it matter which method I use to check timing.
z32z
19:34:58 11/04/11
My preferred method...
Stadsport (PHX)
20:25:45 11/04/11
Thanks. I just tried that. I am reading about 23 degrees
z32z
21:18:10 11/04/11
Worn gear on cam that goes in cas? (n/m)
jlag
21:34:30 11/04/11
2nd on the worn gear in the CAS. (n/m)
ZTicket(Dallas)
22:47:47 11/04/11
Yes, but I would expect an irratic timing. (n/m)
Draker (Eugene, OR)
23:02:22 11/04/11
Not always
Stadsport (PHX)
03:25:21 11/05/11
z32z
09:38:18 11/05/11
No there is a part and procedure to replace. -
Draker (Eugene, OR)
12:18:49 11/05/11
2nd, but I use a Renault plug wire :-)
Dark Diver
16:15:51 11/05/11
Spark plug wire I feel is more precise but have to unplug
craigz96tt
21:47:39 11/04/11
Do you have an aftermarket underdrive pulley ? (n/m)
jlag
16:11:57 11/05/11
What's base idle while checking timing? (n/m)
craigz96tt
18:38:14 11/05/11
Same here , run a high tension wire from coil pack 1
Xteam300TT (South Tx )
17:41:17 11/05/11
